Looking for good machine tool supplier
I'm looking for a .2365" hand reamer.  I checked McMaster and MSC, but no luck.  Can anyone recommend some good online suppliers?
(I hope this doesn't violate the non-commercial spirit of the site, just looking for recommendations)
RE: Looking for good machine tool supplier
That's about the size of hole a 6mm reamer will produce and that should be readily available in the USA.
If you really need that level of accuracy then Metric reamers are available in increments of 0.01mm so a 6.01mm may be nearer as they often cut slightly small. You may have to get a machine type as the tolerances on a hand reamer are often looser and you probably won't get that level of precision by hand anyway!
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
try practicalmachinist.com
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
