PLASTIC MOLDED ROD?
PLASTIC MOLDED ROD?
PLASTIC MOLDED ROD?
Does anyone know if this is special make? Do I need to go get this from a specific mfg company? I do not know where to go with this one. Please help!
glass filled molded rod with phenolic resin per astm d5948
Thank You
CNCMILL smile
RE: PLASTIC MOLDED ROD?
Look for plastics supply houses in your area and ask them.  Good companies stock or can order many types of material and in many different shapes.  Some can even do the processing for you.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
