InputObjectType(0) -> problem???
Hi everybody
Does anyone know why I cannot select a point with the following code. If I replace "Point" by "Face" the code works...
Thank you for your help
This is my code:
InputObjectType(0) = "Point"
Status = Selection.SelectElement2(InputObjectType, "Select the Point to draft", True)
If (Status = "cancel") Then Exit Sub
Set PointToDraft = Selection.Item(1).Value
Selection.Clear
Name1 = PointToDraft.Name
MsgBox (Name1)
RE: InputObjectType(0) -> problem???
you could try this magic word as the automation type for selection "ZeroDim"
Hi PeterGuy,
Thanks for your help, I'll try...
Alex
