Cell Activation After Sort
I am using VBA codes to sort hundred of rows on a sheet.  However, after the sort I have to scroll down to the last row to add a new row.  How do I activate (if that is the correct term) on the cell after the last row.  I have tried the following:
Range(Selection, Selection.End(xlDown)).Offset(1,0).Activate
This code highlights the column of the active cell, but the active cell is at the uppermost cell in the selected column.
Any hints would be appreciated.
RE: Cell Activation After Sort
Couldn't you just select the bottom-most row (65536) in the column, and do a xlUp?
    Range("A65536").Select
    Selection.End(xlUp).Select
That will select the last element in the the column.
melone,
Your solution worked perfectly! Working from the bottom up approaches the task from a different perspective.  Thanks again.  Have a star!
Thunderkid
