Adding a value via a Macro to predetermined part properties??
All,
 In all of our part files we have our preset properties that we require users to fill out. The question I had was, using a macro how could I write in a fixed value? The example I am trying to do is, in the part file we have "Revision". So the user needs to fill in something here in the part file properties dialog box. What I wanted to do is when I creat a part run a macro customized for myself that would automatically put in values like "01" into the "Revision" property. I thoight the line below would do that, but is does't. Could anyone give me a pointer on this?
aBool = Part.AddCustomInfo3("", "Revision", 30, "01")
RE: Adding a value via a Macro to predetermined part properties??
AddCustomInfo3 does not overwrite existing properties.  Usually I make two calls to set a property: one to add the property if it is not there followed by one to change it if it already was there.
If you don't need a return value, you can write functions as subs by removing parentheses:
CODE
Part.AddCustomInfo3 "", "Revision", 30, "01"
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Or first delete the property than add it.
CODE
Part.DeleteCustomInfo2 "", "Revision"
