RMB 'drop list' in sketch mode - customize
When in sketch mode I like to right click and pick the action I want. Currently I want to customize the 'drop list' that shows up when I right click. I've looked thru this website and have not anything that helps. I did learn that when I pick the letter 'S' the sketch menu appears and I can also customize it. But what about the 'drop list'? Any help is appreciated.
SW 2008 SP 3.0
WIN XP SP 2
Dell 380
nVidia FX1400
RE: RMB 'drop list' in sketch mode - customize
To the best of my knowledge, you can't customize the RMB list. You do know the 'S' key is useable other than in just the sketch mode, right?
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo, 4GB RAM, Nvidia 3500M
The closest thing you can do to customizing the rightclick menu is filter what items are visible.  If you select Customize Menu it will let you uncheck items you don't use often.  However, you can not add anything that isn't already there.
Thanks to all for your feedback. Any more comments/suggestions  are welcome.
Thanks again.
