Dimension systems - not behaving as a system
I cannot find the option that allows a dimension system (i.e. - cumulated, stacked, etc) to be modified as such. In other words, when you have created dimension systems, there should be a tab in the properties labelled "system". However, there currently is not. I do not know which option activates it, and I have searched high and low. Can anyone help with this?
Thank you.
Catia Design|Catia Design News|Catia V5 blog
RE: Dimension systems - not behaving as a system
Nevermind - I have found the answer to my own question.
The solution: Click on the "Dimension System Selection Mode" to modify the collective behavior of a dimension system. Toggle it off to be able to modify the properties of any dimension individually. Back on to modify the system again. (etc, etc, etc...)
This is a really easy function to overlook.
