Axial force on a torqued bolt
Say I am tightening a bolt at a specified torque, what is a calculation to find the axial force that bolt is pulling the material?
I've found T=0.2*D*F
where T=torque and D=diameter of bolt.
Is this correct?
RE: Axial force on a torqued bolt
The problem with using torque to establish the tension in a bolt is that the friction in the torque value is unknown.  I think it is better to measure the rotation of the nut to compute the strain in the bolt.  There is a spec on high strength bolting using ASTM A325 and ASTM A490 bolts that could give you some more discussion.  We use the turn-of-the-nut method in my industry.
