Materials with predefined stresses (using SIGINI)
Hi everybody,
I have to apply a field stress in my 3D model (just a very simple field, something like s11=num1; s22=num2; s33=num3).
I used subroutine SIGINI and initially, the stresses are loaded o.k. The problem is that in the second step of the analysis (e.g. the first after INITIAL) the field stress change completely. I read that Abaqus starts de analysis forcing equilibrium, but doing that, the original field stress must change...so that stresses can't be considered true original stresses.
Is it possible to make an analysis starting with a field stress specified by user.
Thanks in advance.
Thanks in advance.
RE: Materials with predefined stresses (using SIGINI)
Can you clarify the nature of initial stresses? If they are any type of residual stresses, then they would have to be in equilibrium.
Gurmeet
Sorry for making lose your time.
Regards.
