Coefficients of thermal expansion over different temp ranges
3
I have found a reference which defines the coefficient of thermal expansion for a gray iron over several different ranges. The puzzler is why they all begin at ambient temp.  Ex. 68-212° is 5.6 and 68-392° is 5.9.  How can this be? What if the final temp falls in both ranges (195°) then you get two answers for the same equation.
RE: Coefficients of thermal expansion over different temp ranges
It's not an equation, as such. Basically the expansion at (212-68) (or 144 degrees temperature change) is 5.6 and at (392-68) is 5.9. Interpolate to get the value at (195-68), as an approximation.
corus
They are giving the AVERAGE thermal expansions per degree for each of these ranges, not very useful if you need another range or at a single temperature
That coefficient is a function of temperature so if you want the expansion over any range you must get a curve of  L vs T where L is the length of the specimen; the coefficient at any temperature would be
 delta L/(L*delta T)
This would be the average over the range delta T. If delta T were very samll, then in the limit it would be the coefficient at that T.
The thermal expansion coefficient of gray iron is reported as 6 x 10 -6 per oF within the materials useful range.
When you run across a set values as you have you should take the range that is the closest to you temperature requirements.
