ASME IX - WPS FOR P8, BUT TEST ON P1 matl.
Could anybody will guide me, that can i qualify welder by using Mild Steel pipe (P1)-Test Piece, but want to use Stanless Steel(P8) WPS ?
Pls. Guide me ASAP.
BPVN
Pls. Guide me ASAP.
BPVN
RE: ASME IX - WPS FOR P8, BUT TEST ON P1 matl.
If you are using SMAW, then that is not the case.
If the welder is already qualified with carbon, just do a test with backing for the SMAW if you have backing rings available.
In addition, you can machine grooves into pipe and use the welding of that groove for the performance test. This is allowed by code.
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
Hi All
I am trying to find the correct paragraph to calculate the minimum base metal thickness for OFW as well as ESW in Section IX of the code book. Could anyone point me in the correct direction.
