Using assembly "scenes" in drafting views
Hi All,
I am using assembly scenes to generate views in drafting. The problem I have is when I have a catdrawing with several sheets, each with a different scene I don't know how to track which scene is in which sheet. I look under links but I don't see any reference to the scene used to generate view.
Thanks in advance
thixoguy (2)
RE: Using assembly "scenes" in drafting views
you could edit the name of the view in the spec tree to reflect which scene you used on that page.
That's a good work around begnor.
thanks
thixoguy(2)
You can find the scene linked to a view by a right click on the view and modify links.
You should see the scene name in the box. You can also point your view to a different scene from there.
Myriam
I would name the scenes to describe what they do (ie: EXPLODED ASM WITHOUT COVER) and name the view to something similar
Thank You to everyone for tips and suggestions
thixoguy
Myriam,
how do you point to a different scene?
I have several created but I only see the one I have selected for the particular view in the box
Thanks for your help
thixoguy
