Reversing the order in an Excel column
I am trying to reverse the order of a data set in a column (1,2,3,4...) to (4,3,2,1..), without having to copy and paste each one individually.  Is there anyway that I can highlight the entire data set and reverse the order with a command in Excel?
RE: Reversing the order in an Excel column
Sort -> Descending
Thanks, I just figured it out.
Well....  How did you do it?
I did just what you said.  For some reason, the first time I tried the command, it only reversed one column at a time.  But after reading your post and highlighting all the columns needed for reversing, it worked.  Thanks for the help.
