Leg Reinforcing Pads
How can the leg reinforcing pads on a vertical tank, with leg eccentricity equal to zero, so the leg is welded to both straight side and bottom head, be extended so it continues below the straight side? When the height is increased the pad goes higher above the top of the leg, not down around the head.
Thanks.
Thanks.
RE: Leg Reinforcing Pads
Consequently, the same restriction, for better or worse, is applied to the leg and reinforcing pad welding. Thus, what you are trying to accomplish (or model actual construction) can't be modeled in COMPRESS.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
Most of the vessels we use are constructed this way. Some are round pipe legs, some are rectangular or I-beam, usually with eccentricity equal to zero. As long as I can attribute the leg error mesaages in Compress to this I can try to find another way to verify the benefit of the legs being attached to the head.
Thanks again.
