Fatigue of cold-worked reinforcing bars
Many old slab bridges (pre-1975) have cold-worked reforcing bars.  Could someone point me to information about the fatigue characteristic of these bars ? This information is required for load-rating older bridges.
RE: Fatigue of cold-worked reinforcing bars
You could also check these from ACI:
#1  How Harmful Is Cold Bending/Straightening of Reinforcing Bars?
Document: CI2104Restrepo
Author(s): J. I. Restrepo, F. J. Crisafulli
Publication: Concrete International
Volume: 21
Issue: 4
Keywords: embrittlement; reinforced concrete; reinforcing steel; strain rate; temperature; tension tests
Date: April 1, 1999
#2  Fatigue of Reinforced Concrete Beams in Air, Chloride Solution, and Sea Water
Document: SP75-15
Author(s): H. Roper and G. B. Hetherington
Publication: Special Publication
Volume: 75
Keywords: beams (supports) '(fracturing');formed rein ; chlorid forcement tests; reinforcing steels; sea water es; corrosion; cracking fatigue (materials); fatigue
Date: September 1, 1982
#3  Reinforcing Steel in Concrete and the Concept of Safety
Document: JL48-37
Author(s): K. Hajnal-Konyi
Publication: Journal Proceedings
Volume: 48
Issue: 3
Keywords: no keywords
Date: March 1, 1952
