what properties does EN24T have?
4
What properties does EN24T have?
RE: what properties does EN24T have?
hi again
The T might be for specifying the tensile strength range of the material.
regards
desertfox
EN24T: 1 1/2% Nickel Chrome Molybdenum steel
Heat treated to the 'T' range = 55/65 tons/sq in.
EN24T / 817M40T is equivalent to AISI 4340 if that helps.
T is, as geoffthehammer said, heat treated to a specific range, in metric 850 to 1000MPa.
