plastic for casting pattern
What are the best choices for a machinable plastic for use as a casting pattern, used in sand castings.?
Wood is commom, but i would like something that is a little more robust.
www.retallickeng.com.au
Was told it couldnt be done, so
i went and did it!
RE: plastic for casting pattern
If you can give a little more information it will be helpful.
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
I will be starting with petrobond sand molds and move onto a phenolic bonded sand if i need higher volumes.
i went and did it!
My experience in epoxy is for laying up molds using carbon, kevlar and fibregrass.
i went and did it!
If you need one,send along a drawing I shall get one for you free,!
Are there any plastics that are also suitable? eg, nylon, acetel, as these are easy enough to source. I would be suprised if plastics arent used!
i went and did it!
