High pressure condensate temperature
Just out of curiousity, may I know what is the temperature of a high pressure condensate (say 150psig). I would like to estimate the expansion of the condensate pipe handling the riser condensate drip of the 150 high pressure steam. I know that when the condensate passes thru the trap (if full pressure differential), it might reduce it to a 0psig condensate...but how does this whole thing work...plzzz
RE: High pressure condensate temperature
