Drawing Dimensions RED in solidwork 2008
I have migrated from SW2007 to SW2008. Almost all my Sw2007 drawing dimensions are appearing RED. Any body here know why?
Appriciate your responses in adv.
BMR
BMR
RE: Drawing Dimensions RED in solidwork 2008
Just a thought as I have had a similar issue in the past where a logo that I inserted from autocad created a text layer in the drawing and the color was red. All text I inserted after that came in red. It took a little searching to figure it out.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Did someone change the color settings for driving, driven or dangling dimensions under tools/system options/colors? I have our standard for dangling set for the color red. This way I know when dimension links drop from the geometry of the model, and flags us to fix the dimensions
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--"Coffee Talk" Mike Myers SNL
I checked my layer settings are default. There is no RED color assigned to any layer.
I even checked the color settings for Driving, driven , dangling, overdefined etc... they are default. Nothing assigned to red.
Its OK, this is not throwing me out though, but I was curious.
BMR
Here is what I saw:
http://fil
Options> Colors> Color Scheme Settings>Annotations> Edit.
Check the slider & pickpoint under annotations, do not rely on the color box, as I did. Happened to several other machines also.
