ALUMINUM QQ-A-225-6
ALUMINUM QQ-A-225-6
I have an application that calls out aluminum tubing 2024 per QQ-A-225-6.
The size is 1.3125 od x .755 ± .0025.
Can anyone tell me if this is a common size? Is this a special make?
Is there a place where I can get this material? I cannot seem to find it.
THANK YOU
CNCMILL
RE: ALUMINUM QQ-A-225-6
Thank You
CNCMILL
For extruded tube [which is what you actually described] specify: 2024-(temper) per AMS-QQ-A-200/3 [extruded BAR, ROD, SHAPES, TUBE AND WIRE]
CAUTION: If these materials are for NON-AEROSPACE use, then the ASTM equivalent material is "OK". Otherwise... stick to the AMS material!!!!!!
Regards, Wil Taylor
