90 degree Moment Connection
How would one go about detailing a moment connection for a beam and column connection. It is a relatively small frame for a all glass vestibule (11'x14') Do you think I could just specify a 45 degree mitre and groove weld the W8 (beam) and W6 (column)?
What have you guys done in this situation?
RC
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
RE: 90 degree Moment Connection
Check the column flanges and webs as required for stiffeners.
I had an architect suggest exactly the same thing so I steered them towards allowing 2 stiffeners in line with the inside flanges so that they form a rectangle. If theseare ground back and prepared as architecturalyposetell then it looks pretty good and works structurally.
Thanks guys!
RC
Edmund Burke
That's exactly what I was thinking. Since it so small, they could probably just do all the welding in shop and it would be brought out as a single unit. Thanks again for the thoughts and feedback.
RC
Edmund Burke
