Pass Partition Weight
Why doesn't compress calculate the weight of pass partition(s)?
RE: Pass Partition Weight
Send your request to support "at" codeware.com. Or use the form at www.codeware.com/support/contact.html
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
