Expansion Joint Weight
Why doesn't Compress calculate the weight of an expansion joint?
RE: Expansion Joint Weight
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
