Turbine Engine: No Pistons, no lube, 30% better on gas!
http ://gas2.or g/2008/06/ 09/turbine -engine-no -pistons-n o-lube-30- better-fue l-economy/
[img]http://gas2.org/files/2008/06/turbine_engine.jpg[/img]
I think my Thermodynamics text book needs to be rewritten now.
Quote:
The DCGT is powered by an innovative new electromagnetic isothermal combustion process that produces complete combustion of fuel-oxidized mixtures in cyclic detonations.
The high-pressure gasses produced by these detonations drive a unique turbine producing shaft horsepower. The engine's unique combustion process allows the DCGT to operate with blower air at low static pressure, negating the necessity of compressing and preheating fuel-oxidizer mixtures prior to combustion. Once the compression of fuel-oxidizer mixtures has been eliminated, the engine both achieves higher thermal efficiency in a simplified mechanical structure, and provides significant advantages over current diesel, gasoline, and gas turbine engines.
RE: Turbine Engine: No Pistons, no lube, 30% better on gas!
there's at least one guy over at http://au
This engine versus a typical gas turbine could show improved effiecency because it uses a positive displacement air compressor. The power turbines are closed impellar, don't know how they handle high temp and loads.
Um, well, no. Turbines are generally more efficient than piston engines at fixed power outputs, and can operate for longer durations between overhauls. That's why you see a lot of newer, large, fixed power installations using gas turbine engines.
But, turbines don't throttle well, i.e. they are relatively inefficient when operating below their design power output level. Since operation across a wide range of loads/speeds is a necessary attribute for automotive engines, turbines don't compare well to pistons.
KENAT, probably the least qualified checker you'll ever meet...
http://www.microturbine.com/
http:
It is just conceivable that a GT hybrid might make sense, but I think that a conventional turbo-diesel is a better bet.
Small GTs just aren't very efficient.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Again, the efficiency of a GT drops like a rock when it's throttled, whereas a piston engine can operate over a comparatively wider power range with reasonable efficiency. A hybrid that took advantage of the throttling ability could perhaps have less battery weight to lug around, giving better vehicle mileage?
No turbo.
Automotive diesels can achieve 41% when turbocharged.
Cheers
Greg Locock
I meant to say that boost would be required to beat the turbine "by a significant amount", my (out of date!) numbers said 30% was about where a typical nat-aspirated gasoline engine can run.
Yes, the capstone nubmer is an electrical output efficiency. They are known in the GT biz as kind of weird, they never quote the turbine's shaft power/efficiency figures, only system figures. Part of their story is a very efficient electrical generation control system (I imagine lots of digital circuitry and inverter stuff), so if that were adapted to the Prius engine, perhaps we're still talking close numbers, with the Prius beating it handily by several points.
My point is (was) that only 20 years ago, "small" turbines were in the 1000 kW range, and had efficiencies in the 20's. They've come a long ways in making smaller versions with good efficiency. But that rising tide lifts all boats, and it appears piston engines still compete well, and will likely continue to do so, in the "small" sizes needed for typical (land) automotive uses.
Regarding throttling - a GT just can't idle, it must run at near the same mass flow of air, or the turbine stalls. You can reduce the fuel flow only so far before the burners won't stay lit (ok, with hydrogen fuel I could keep them lit...but let's not go there). There are some fancy ideas regarding bypass valves and multi-spool designs, but you might as well talk about multi-engines and boosted piston engines then.
A piston engine, however, can idle at a very small fraction of its best-consumption rpm and mass flow, and so can idle with comparatively low fuel consumption. And starting/restarting a turbine is a fuel-consumptive, slow process in comparison to piston engines also.
So, no, I agree with Greg that they won't be seen in large numbers on the roads very soon.
So, let's talk rocket engines instead: strap a solid-fuel booster onto your favorite chassis, light the fuse...as long as you didn't have any stoplights or turns, you could boost to Mach 3, and coast the rest of the way...:)
I'm assuming that the turbine set has a better power to weight ratio than the pseudo-Atkinson engine in the Prius, note hat it also needs a gearbox or traction motor rather larger than the Prius'.
Cheers
Greg Locock
Also, I had another look at their so-called hybrid vehicle "solution", which burns diesel/kerosene. 25% electrical efficiency, at 29 kW output.
Worse, I don't think these meet CARB standards, and the exhaust temperature may be too low to "light off" a catalytic converter:
NOx Emissions @ 15% O2 < 35 ppmvd
NOx/Electrical Output 0.846 g/bhp-hr (< 2.5 lb/MWh)
Exhaust Gas Temperature 275˚C (530˚F)
And the kicker - that device weighs 1300 lbs (with the genset).
Dunno why this version shows with a recuperator, unless they are adding on a steam turbine to pull some work out of the exhaust heat?
Ah well. Reality sets in again.
http://www.aixro.de/
If it were combined with a turbo charger it could produce the same amount of power at a lower rpm and thus increase durability and efficiency. However, durability might not be this important in an application where the combustion engine is only needed to extend the range of an electric vehicle (and thus not be operated as frequently and extensively as in a normal car (GM Volt)).
Keep in mind, a piston or rotary engine also has no need for a reduction gear to operate the generator.
A piston or rotary engine with turbo is principally comparable with a gasturbine with a moving combustion chamber allowing higher pressure ratios and higher peak temperatures. Rolls Royce even patented a aircraft gasturbine concept with an integrated rotary engine:
http://www
(Although the drawing does not make much sense, as the airflow produced by the axial flow compressor of the gasturbine is obviously much higher than that of the relatively small rotary engine).
GM produced a Hybrid-Prototype with a series Gasturbine producing 40 kW at a weight of 100 kg for the entire gen-set:
h
Simple cycle gas turbines are typically low efficiency because there is so much heat lost in the exhaust. When that heat can be recovered via a recuperator or a heat recover steam generator (HRSG) and sent to a 'bottoming cycle' steam turbine, the plant thermal efficiencies start approaching the 50% range.
Now enter the fairly new GE LMS-100 (Google works wonders) where with the use of an intercooler and multiple stages of compression, the simple cycle efficiencies are starting to approach the high '50 percentages. (It has just occurred to me to go ask the LMS-100 designers why they don't have a recuperator too-something else to do.)
Can this concept be downsized? There may be a Bill Gates building just such a thing in his garage as we debate this.
Because of the point made regarding throttling a gas turbne, the best approach would be to utilize such a device in a hybrid configuration because of the difficulty noted in operating the combustion turbines at reduced speeds.
Now I can just picture some type of miniture LMS-100 configuration type of combustion turbine driving a generator topping off a battery in a Prius. Wow. Now where is my patent attorney?
Let's all try to remember this thread in about 5 years IF fuel prices in the USA stay where they are today or rise. I don't think our imaginations are good enough to conjure up what will be on the scene at that time.
rmw
http://www.gizmag.com/go/4936/
Unfortunately, downsizing in general increases the surface to volume ratio of any engine/turbine, which again reduces efficiency.
Regardless: Most important is, that the gen-set for the hybrid stays affordable.
You are correct, but a recup cycle on such a small device doesn't seem like it provides much benefit, at least not compared to a second compressor stage and intercooling (like your GE example). The real reason for the recup on the Capstone turbine is because they sell the devices primarily for stationary standby electrical generation with cogeneration of hot water or steam heating; the recuperator I think is just along for the ride. At least, I don't see a preheater HX in the cutaway views.
I stand ready to assist you in giving birth to a multi-stage, intercooled, small GT hybrid. Will file this in my whacko ideas notebook.
I suggest making the 'power generator' modular. You could have different versions at different performance/price points.
One module could be optimized for natural/biogas, one could be a fuel cell, one could be optimized for whichever bio fuel is most promising etc. You could bleed the greenies dry based on which fuel source they have locally available, how much they're willing to spend...
So then could you name a turbine that is close to 50% efficient?
I can name a recip engine that is.
Rmw already named a turbine with 54% efficiency, although it has a secondary loop running a steam cycle. The GE LM-100 turbine generates 44% thermal efficiency at the output shaft in simple-cycle mode. My post compares a combined-cycle turbine to a piston engine running with boost (turbo- or super-charging), i.e. there is additional complexity to create the higher efficiency. Although, I'd also argue, with a turbine wrapped around a piston engine, is it really a piston engine anymore, or is it a turbine with a piston booster, or...?
Another example is the Solar Turbine Mars 250, in clean turbine (no secondary loops) mode, it has a thermal efficiency of 39%, and can be pushed to around 50% with added steam loops.
I think also on specialized long range missions, where range and endurance are more critical than speed, a diesel turbocompound might be able to compete, considering the trade-off of fuel efficiency versus powerplant power density (i.e. net weight of fuel plus engines). It is interesting to consider the effect of auxilliary take-off power (e.g. JATO) on this trade-off.
I have an example of a turbodiesel engine that is approx 42% efficient at its best operating point. Not only that, but it is completely practical for day-to-day use in an automotive application and doesn't have problems with varying loads (although obviously the efficiency will drop away from the best-efficiency point). No steam loops, no turbo compounding, no engine stop-start unless I do it myself (i.e. still room for improvement in overall powertrain efficiency, if there is a business case for it). It is a bone stock 1.9 litre Volkswagen TDI that is produced in quantities of many hundreds of thousands per year. The newest versions, just coming onto the market now, meet US EPA Tier 2 bin 5 and maintain approximately the same peak thermal efficiency.
Diesel engines on the scale of large ships exceed 50%, and my understanding is that modern diesels on the scale of those used in on-the-road transport trucks approach 50%.
http://people.bath.ac.uk/ccsshb/12cyl/
www.retallickeng.com.au
Was told it couldnt be done, so
i went and did it!
23 MW MAN B&W Diesel S80ME-C Mk7 two-stroke marine engine 155 g /kWh 54.4%
Cheers
Greg Locock
That would be the exception, assuming we're talking about engines with regulated emissions (I can't think of an example outside of some research projects in either case, but I'm less familiar with the unregulated engines). 43% would be more typical.
And thanks Greglocock
They've never left, at least for light GA planes; they're cheaper enough in initial cost, and light planes tend to log fewer hours, so the higher maintenance costs for piston engines never really overcomes a steeper up-front cost.
There's been a lot of talk over the years about turbodiesels for aircraft, but there's only ever been one production diesel aircraft engine that I'm aware of...and the bomber it powered got shot down way too often, so the Germans stopped building them fairly early in WW1 (wrong mission for that engine I'd say). The article on wikipedia for the Continental engine company says their president wants to develop a light diesel to replace their piston engines, remarking that 100-octane avgas is becoming hard to find and expensive, relative to Jet-A.
You may see turboprops more frequently in the future, on freighter airplanes operating out of remote terminals, as they are more efficient, but the prop limits top speed. They are limited to lighter aircraft for near-city airports, as higher-powered props violate FAA noise limits on takeoffs (though those might change if fuel price pressure continues). But the greater frequency of required overhauls for piston engines will limit their use compared to turbines for large commercial aircraft. And the longer MTBF for modern turbines allows planes like the 757, 767, 777, and presumably 787, to be certified for long overwater flights, something the FAA was restricting to 4-engine planes only before the GE90 came along.
Those big, efficient ship engines probably compare well in maintenance frequency (dunno), but weight for a ship engine (all that extra metal for a big crosshead don't come with built-in lightness) is not critical either; I just can't see the one that Greg posted a photo of hanging off a 797 wing...maybe an Airbus though.
The comments on fuel efficiency are still right on all counts, the piston still beats a turbine in most ways. The Voyager round-the-world flight (30,000 miles plus, nonstop, no refueling) was done with the venerable old Continental opposed 4-cylinder, a mainstay of light aircraft. But it hasn't been flown again, either...it has a TBO of 1800 hours of operation. Still, if you want to stay up a long time, you need to use as little fuel as possible, and pistons get you there apparently, see ht
...although the time aloft record of 69+ days, the two guys who had a fuel truck chasing their Cessna 172 down roads in the Mojave desert to refuel...that's just nuts :). Note that they had to quit at about 1500+ hours of engine operating, because they couldn't get enough power out of it to climb away from the truck anymore.
Fun discussion. I'm done. You motorheads can go back to muttering about ring friction and I'll leave ya alone.
Recip planes can and do approach current and past airliner speeds, just look at some of the speeds flown at the reno airraces.
The question I would like to ask, what are the horse power requirements to keep something like a 757 flying at say 500 mph at 30,000 feet altitude?
Do you think, with the money that can be spent developing and manufacturing a commercial aviation engine today, that a lightweight diesel engine might be brought much closer to the MBTF of a turbine engine, assuming a market was there?
P=F*v
F=m*g/(L/D)
L/D is about 20 from memory
Gives about 150 hp per ton
Cheers
Greg Locock
Hemi, You Are Correct Sir! I was off by one war, dunno where that slip came from, I plead post-vacation fatigue.
For the 757, it is supposed to use two jets with rated thrust of about 40,000 lbf, and cruises at 530 mph. This gives a power requirement of 62.2e6 ft-lb/sec, or about 113,000 horsepower.
"Do you think, with the money that can be spent developing and manufacturing a commercial aviation engine today, that a lightweight diesel engine might be brought much closer to the MBTF of a turbine engine, assuming a market was there? "
You guys in this automotive forum have a better idea about the likely improvements in MTBF for piston engines. Somewhere I have read that the MTBF for the boosted versions of the old radials (used as fighter engines in WWII) was halved for every 50% increase in power. Right now, turbines are pushing 5000 hours TBO, and most mechanics I've talked to say they really don't need any work done at the overhaul, typically, and can go 10000 to 15000 hours before you have to do anything major. 2000 hours is about the limit for NA piston engines before a rebuild is required, historically, but then, my Toyota will probably go 1.5 to 2x that figure.
The power to weight ratio is an interesting number to kick around. A GE90, putting out rated thrust at 500 mph, generates 120,000 horsepower, and weighs 16k lbm, for a specific power of about 7 hp/lbm. The P&W R28000 18-cyl. supercharged, air-cooled, water-injection radial developed 2100 hp, and had a PTWR of about 0.9. Not that engine weight is a huge penalty for an airliner, but every pound you can shave in airframe weight is payload.
It's interesting, I think, to also point out that flying is not a fuel efficient transport method by any measure, except speed. The best miles per gallon (MPG) is from the distance record flights, i.e. aircraft purpose-designed for best possible range. The Voyager went 26,000 miles, burning about 6900 lbs of fuel (I had to calculate that number, not sure about it, but it ought to be close). Using 6 lb/gal (?) I calculate the Voyager got about 23 MPG for its flight. Not bad, but there are small cars beating that by about 2x today. The Virgin Atlantic Global Flyer, a turbine-powered Rutan record-setting contraption, flew 25,772 miles and presumably burnt about 18,000 lbs of fuel. Again using 6 lb/gal (somebody got better numbers for fuel density?) gives a figure of about 8.6 MPG. Both planes flew at about the same average airspeed, so this is a pretty good comparison of the relative efficiency of the two powerplants, for low-speed, max. range flight.
Oh, and its a P&W R-2800 not 28000. Sheesh.
A heavier but more efficient engine offsets its weight penalty by requiring less fuel for a given range. So the net (non-fuel) payload difference depends on the engine weight differential and the required range.
Um. Yes, but no. Nobody is operating DC-3 aircraft in the US market, as passenger planes, because they fly so damn slow. You can't pay the pilots, and turn the aircraft around fast enough to book enough passengers per day, and pay the people who sit at the gate and take tickets, etc. etc. to make that aircraft pay for itself. Even though its MPG is pretty darn good, you just can't save enough money on gas to justify the slower flight speed. Or at least, you used to not be able to. A DC-3 works if you are hauling something that 'absolutely positively doesn't have to be there overnight, and you fly from deserted airfields... Or make mutliple short hops (skydiver aircraft).
Within a narrow range of flight speeds, say 500 to 600 mph, fuel efficiency matters, for current airliners. Drop much below 500 mph, and you have a plane that only pays on short runs, where the speed difference is enough for people to justify flying vs. driving, but not enough to justify a jet. Turboprop commuter planes are filling this niche currently. But in places where high-speed rail has become available, short-flight prop planes have seen drops in passenger volume.
"A heavier but more efficient engine offsets its weight penalty by requiring less fuel for a given range."
Well, it can, if the range is long enough and the weight of fuel great enough. Agree with your second statement.
If diesel engines are going to make inroads, it will begin with freight and possibly short run passenger transport. Like you say, where high-speed surface travel is an option, it will be more difficult for aircraft to compete.
It's too bad that propfans are so noisy. They would allow recip engines to approach 500mph, if I recall correctly the propfan performance envelope.
No I don't think so. It is already hidden away in there.
Cheers
Greg Locock
In his first equation, he relates total drag (force) to power and velocity
I'm not sure what velocity he assumed (for "cruise") in the first equation.
In his second equation, he relates total drag (force) to lift (force), assuming a glide ratio of 20:1. A 747 at cruise is in the neighborhood of 17:1 (see wikipedia: http://en.wikipedia.org/wiki/Lift-to-drag_ratio).
The estimate misses off-cruise conditions where L/D may be less favorable, such as takeoff, and depends on having a good cruise velocity as input to the first equation.
Cheers
Greg Locock
"It's too bad that propfans are so noisy. They would allow recip engines to approach 500mph, if I recall correctly the propfan performance envelope. "
Well, good turboprops today can (just) reach 500 mph, so yes, a 500 mph turbodiesel is not unlikely...but, yes, props are noisy, and the noise goes up fast as the power level (airframe weight/payload) of the engine increases. The stupid thing is, most airports (at least out here on the left coast) were purposely built away from major urban centers. Then, because commerce moved to be near the airports, housing followed the commerce...and then people who'd built their spanking new home under the takeoff pattern started complaining about the noise. Same thing happened with a local speedway here. I say, f-- 'em, if you're stupid enough to build next to a noise source, live with it. But enough of them complained, and the FAA started regulating noise. If fuel prices continue upwards, they may need to raise that noise limit, at least for cargo aircraft.
ht
or pulse detonation engines:
http://
could increase efficiency without increasing engine weight significantly.
Also, a turbofan has less cross sectional at the same thrust than an aircraft with propeller. At least at high speeds this should be an efficiency advantage of turbofans over propellers.
PDE's hold promise, but are noiser and louder than props; and the weight penalties for valving/containing high pressures so far don't make them very attractive. GE thinks they may adapt them to ground-based aero-derivative turbines in 10 years (basically, it's still a long shot). A company I interviewed with years back, called Adroit Tech. Systems here in Seattle area, was doing quite a bit of research on PDEs, with Tom Bussing as the company president (nice guy, but he wanted cheap young engineers willing to "donate" 80+ hrs/week to the project for very low pay). The company got bought up by P&W, then ... assimilated. Several old friends were
digestedvariously affected by the change. They were probably the farthest along in testing of PDE's but today most of the research on PDE's at P&W is either under deep cover (hah) or just not in existence, no news since 2003 or so.here is one place you may see PDE's soon: htt
GE (one of P&W's biggest competitors) is apparently now operating a research program, looking into a valveless PDE... we shall see.
Great, 2.5 bad ideas in one sentence. The only demonstrated range for an air car is 7 km. carbon fibre is a fairly stupid material to build a real road going car from, in a greenhouse world.
The microturbine may have some merits, so it is only a half bad idea. Work out how to keep it warm enough and get back to me.
Cheers
Greg Locock
The resulting structure has some virtues - it can be light and stiff, but it is not that much lighter or stiffer than other composites. In terms of crash performance it is not very good, as its compressive properties are poor.
The resins themselves are made from oil, and again do not recycle very usefully, and have short and long term environmental problems/costs.
RMI, and the Hypercar project, and UCS, all pushed lightweight composite construction for road cars whilst ignoring the real world costs associated with it. Personally I regard the Hypercar project as one of the most sickening (if succesful) bits of greenwashing and misdirection I have ever seen.
If you look at real world affordable composite cars /that meet crash requirements/, and look at their weight, you will notice that they aren't especially light for their size. Odd that.
Cheers
Greg Locock
Does it really take that much more energy to produce some parts of the car with carbon fiber composites?
As opposed to the convential slow carbon fiber process using epoxy, fiber forge uses thermoplasts (polyamid). Since this reduces process time significantly, it should also reduce costs.
http://w
(Btw, you can cheer up, the Hypercar was not succesful - Fiberforge is apparently all what's left).
The compressive properties are poor, but the actual maincell of the car should not be compressed. For example car sections like the roof or the floor can be made out of carbon composites.
Apart from composites: It's at least interesting to note that there are still so few cars with plastic (no composites) hoods, fenders and door panels which could be easily be recycled.
But there is change: Mazda might actually be one of the first car brands which started to make lighter cars instead of continuing to make them heavier. Although using high strength steel instead of composites.
And if carbon fibre is too costly and energy intensive one can also produce composite parts without having to use carbon fibres:
htt
Poor body gaps or panel alignment I imagine does not at all help with aero drag.
I doubt the average life of a car is 200,000Km. I suspect it is more than that if scrapped due to normal wear and tear, but a significant number will be cut well short by accident damage and I would expect that would result in a lower average.
Also, not all panels last the life of the car.
I thought carbon had good compressive strength. It's Aramid fibre that has lousy compressive strength. Carbon is poor in impact and elongation.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Apparently the problems related with the different coefficients of thermal expansion can be solved.
Chrysler built a full size car with an aluminium frame and plastic body panels weighing only 1020 kg but at extra costs of $7500. Even with the all-plastic body and sparse frame, the ESX3 passes all government crash tests and will carry a family of five comfortably.
http
And the floor and roof parts are not likely to be exchanged over the lifetime of a car. The maincell of a car must not collapse, therefore overall stiffness and strength in this area is more important than impact strength.
Although impact strength does not seem to be that bad:
http://www.youtube.com/watch?v=imfHBcqzLfI
(scroll to about half the movie)
Carbon actually has a lower coefficient of thermal expansion than steel:
http:
http://
The question remains: Can one bring the cost down of carbon fiber parts in a mass production set-up.
Teslamotors uses carbon fiber body parts and writes:
http://www.teslamotors.com/blog4/?p=50
Depending on how it's processed, for example, a carbon fiber-reinforced plastic part can replace an equivalent steel part using less than 30 percent of the original part's mass.
Carbon fiber on its own isn't much use, though. It's like a very thin fishing line, it is only strong in tension (when you try to break it by pulling it along its length).So, to make a panel that is strong in all directions, carbon fiber is typically woven into cloth (to give it strength in two directions) and then the carbon fiber cloth is encapsulated in plastic. In our case, it is encapsulated in epoxy resin – it has a higher specific strength than the alternatives. The epoxy is strong in compression but relatively weak in tension, so the two materials act together to produce a panel strong in tension and compression.
Carbon fiber parts that you see on some cars, especially aftermarket products, are produced using carbon fiber cloth pre-impregnated with resin (abbreviated to 'prepreg') that is heated and pressed against a former in a pressurized oven called an autoclave. The very high temperature and pressure squeeze the air out of the cloth and force the resin to flow around the fiber and create a consolidated molded panel.
This can produce very lightweight and very stiff components, but with a couple of drawbacks. First, the cost of producing the parts is very high because they need a long time to fully cure in the autoclave and the process isn't cheap. (If you think the Tesla Roadster is expensive now, you should consider how much it would cost if we added several thousand dollars worth of autoclaved carbon panels.) Second, there aren't many manufacturers with enough autoclave space to produce a whole set of body panels at the rate we need.
An alternative to using an autoclave is to "vac-bag" the parts. This is a similar and less expensive approach that doesn't use an autoclave but the drawback is that, as the name suggests, you can only apply atmospheric pressure to the parts (by creating a partial vacuum in a bag that surrounds the mold with prepreg carbon loaded onto it). The pressure isn't high enough to fully consolidate the resin into the fiber so the final panel's surface isn't of a consistently high enough level of quality for a car like the Tesla Roadster.
The process we ultimately adopted for our body panels is Resin Transfer Molding (RTM), which uses what's called a "closed mold." Two huge blocks of steel are machined and polished so that when they're nested together there's a gap between them of less than 2mm representing the shape of the part we want. We lay carbon fiber mat (and some additional material we discuss in more detail below) against the concave surface of the tool, bring the other half of the tool into place to create the cavity, and then inject resin to fill the gap. This technique allows us to control thickness (which keeps weight down), reduce processing time, and maintain a very good level of surface quality. An additional advantage of using a closed-mold tool is that we can vary the thickness of the part in key areas to integrate features that add strength or provide a location for mounting hinges, etc ...
This process however still appears to be more elaborate than what fiber forge presents.
Not precisely true.
It can deform, but it has to hold enough shape to protect the occupants.
Nice thing about steel- it can take more than one hit. If you have more than one impact (rollover or multi-car accident) the composite car tends to frag in all directions, leaving nothing to enclose the unfortunate occupants.
Cheers
Jay
Jay Maechtlen
http://home.covad.net/~jmaechtlen/
h
Things like:-
HANS devices.
Helmets.
Seat belts.
Fire extinguishers.
Run off areas.
Angles of barriers to direction of travel.
Soft barriers.
Rescue crews.
Fuel cells.
Drivers apparel.
Rigid pod surrounded by energy absorbig items that crumple or break of thus absorbing energy from the impact.
There is a LOT more to the properties of a composite structure than the properties of just one component.
Fibre to resin ratio.
Type of resin.
Chemical types of fibre.
Geometry of fibre.
Surface coatings on fibre.
Fibre orientation.
Yarn structure.
Fabric structure.
Other components that may be used as fillers or laminated layers, like hard shins or lightweight cores or stringers or ribs.
F1 has acces to very high budgets and can afford complex designs and short if highly stressed life of components.
Everyday drivers are best kept relatively simple and cheap and need long life at low stress. Carbon fibre composites have a long way to go to offer value in everyday drivers.
Bottom line.
Refer back to greglocock's post eighth of July
The cost of carbon fibre is the problem and not the mechanical properties of the material.
Besides, F1 uses epoxy resins, fibre forge uses injection moldable thermoplast, which is obviously less costly but may still be more expensive than steel.
On July 12th I posted lots of facts. I simply prefer facts over opinions.
Btw, Toyota just made a light weight car out of carbon fiber reinforced plastic with a curbweight of only 440 kg, showing that weight can be reduced significantly:
http://w
Again the costs may be too high, but do you suggest that the lightweight, rigidity and structural safety claim is a scam from Toyota?
The thermoplastic matrix composites are generally somewhat down on most physicals vs epoxy matrix, but they have a very significant benefit in that they can be thermoformed, but this also severely limits design possibilities as they can only be formed into a simple shape.
One problem with manufacturing thermoplastic composite sheet with fabric reinforcement is wetting the fibre wit the resin to get a good bond. With thermosets, there is time to work the resin in and the air out.
Some of the problems with designing carbon fibre monocoques that are efficient and crash proof are: surface finish, integration of hardpoints, post yield behaviour, refinement.
The second of those problems is so great that I would be tempted to integrate the suspension arms into the layup, ie use composite hinges, and carbon fibre arms.
In practical terms if you are interested in panel properties (ie out of plane stiffness) then the gain in going from S glass to CF is small.
Cheers
Greg Locock
