Invisible text in AutoCAD 2002
I am having trouble using the text in the AutoCad 2002 version. When using the text command, I specify the text window and the text editor window opens. When I try to type text in that window the text is invisible and the only way I can see it is if I highlight it.
Any thoughts?
RE: Invisible text in AutoCAD 2002
Do you have a colour problem?
Text colour ≠ background colour
Lothar
ADT 2004
Hi Exxit,
No my text color is set to Bylayer and the Bylayer color is white. The background color is black.
Can you attach a file here in the forum?
Lothar
ADT 2004
If I recall, it may have something to do with Windows Display Properties > Appearance > Effects > Smooth edges ?
Rt-clk on your desktop.
____________________
Acad2008, Terramodel
ok, yes, but it is the "mtext" command, not "text".
L.
ADT 2004
Thanks Ipseifert! It worked. To clarify it was right click on the desktop>properties>appearance>effects>uncheck smooth edges.
Thanks to all
