User defined pattern - anchor point
Hello Chaps
Im using V5 release 14, and notice something curious with the anchor point in user defined pattern.
If the anchor point is created on the fly with the right click contextual menu as the user pattern is being created, it works fine - just as expected.
However.... if I subsequently edit the pattern definition and change the anchor point, I get the diagnostic panel 'feature involved in update cycle'.
I can't believe it, I think I must be missing a trick.
Any comments?
Thanks.
