Roof wind load on drawings
I am used to seeing plans that include the wind load resistance required of the components and cladding. Further this information is usually provided by the structural engineer and is given in psf. My current project's plans (beachside Florida) just say 150 mph wind. Shouldn't the structural engineer be the one to convert that to psf for each different area?
RE: Roof wind load on drawings
slickdeals - I looked in the codes but have not found it yet - if you find it I'd appreciate hearing from you.
I'm the owners rep on this project, trying to get timely answers for the contractor from slow responding architect/professionals.
The following information related to wind loads shall be shown, regardless of whether wind loads govern the design of the lateral force resisting system of the building:
5. Components and cladding. The design wind pressures in terms of psf (KN/m2) to be used for the design of exterior component and cladding materials not specifically designed by the registered design professional
Dik
I could get in touch with you if you want to recommend/hire us. :)
