Part Attribute used in Annotation
NX5
Now I could obviously use two separate attributes, but is there a way that an attribute can contain a control character (carriage return / line feed) to wrap into a two line annotation ?
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
RE: Part Attribute used in Annotation
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
there is another way you can get this to work. Instead of adding in a normal note and linking it to the attribute, I have found that you can insert a tabular note and do the same thing, giving you more options.
Firstly, add the tabular note. I generally delete all the excess rows and columns, until I am left with 1 cell. You can then hide the border of that cell. Next, you double click the cell, and type in the value of the attribute you wish to use eg. <W@DB_PART_DESC>
Next, right-click on the cell to edit it's "Cell Style". There is a tab called "Fit Methods" and from here you can select to wrap text/auto size row/autosize text/autosize column etc.
Ross
NX5.0.4.1 WinXP SP2
SolidWorks 2007
