Metal stud size for 3" round cut-outs
Have a client who needs to run an insulated 3/4" condensate pipe (OD 2 7/8") a dozen feet or so within a 6", non bearing, 9ft height metal stud wall.  I need an opening 3" round to run the pipe.
Most stud suppliers I've found limit knockout sizes to something around 1 1/2" square, or 3/4" wide x 1 5/8" long.
Does any vendor offer this this service?  Ie, "If you keep cut outs 24" from ends, use a 10g reinforcement ring on both sides, you can cut an opening 3" diameter" in our 2x8, 18 g studs", or something similar.
The pipe is sloped at 1/4"/ft, so the opening would not be at the same height in each stud; that's why the openings need to be field applied.
The other option is to build a pair of 2x4 stud walls, with the pipe gap in the middle.  But I would rather not lose the space.
RE: Metal stud size for 3" round cut-outs
If its non-bearing - where is the problem... Could go to a 2x8 stud or turn a 2x4 stud perpendicular to the original 2x6 studs fro added support.
It could be a problem if it is an exterior wall and supports wind loading.
Perhaps the easiest solution is to cut each stud on one side at the location of a punched opening, install the conduit, then put a 16 GA or heavier strap on the cut flange to restore the flange.
I think the 1-1/2" X 4" punched opening is standard.
DaveAtkins
