JET-A density vs temperature
Is there a useable formula to correlate temperature to fuel density particularly Jet-A ? I am aware of the Coefficient of Thermal Expansion value of 999 x 10E-6 (ie .00099) per Deg C but reluctant to use this as there may be other variables to consider... Trying to plan airplane fuel requirements in gallons since most flight planning systems work in pounds.
RE: JET-A density vs temperature
Unless anyone can advise any specific constants to use other than the default values then I think this will suit but you'll need to convert from kg/m3 to whatever alternative you need.
JMW
www.ViscoAnalyser.com
