spot welder for nichrome wire
I need to make a 120 volt, 300 watt heater using 32 gauge nichrome wire (10.5 ohms per ft)and have a need to make reliable electrical connection from the nichrome wire to the 16 gauge copper lead wires. I tried silver soldering (oxy acetylene with stainless flux) but the silver solder wire I had was too big and I melted the fine nichrome wire. I have read a capacitive discharge spot welder may just be the ticket. Anyone know approx how many micro farads in electrolytic capacitors I need and what voltage I should be charging it to for a good weld?
RE: spot welder for nichrome wire
Melting the nichrome while silver soldering, however, is simply a problem with your technique. Using a smaller torch tip and directing the heat mainly on the copper wire should work.
I used 10,000 microfarads charged to about 70 volts.
The trick is to discharge quickly, just touching it on won't work.
Make good contact then discharge the capacitor through an SCR.
I think for a one off Compositepro has the answer you are looking for or you could crimp it.
Roy
Keith Cress
I'd agree on the (suitable) terminal block approach above to tie the copper to the nichrome and, to provide a thermal barrier (enough bulk in the terminal block to provide heat sinking) at the connection.
