Compact flanges or Grayloc type gasket details
Does anyone know why compact flanges are designed to have flange to flange face contact at the heel and toe? Could you eliminate the flange to flange face contact and locate the gasket at the ID of the flange similar to a grayloc type gasket and have no flange face contact?
Does anyone know what the taper is on grayloc gaskets? What purpose does the spacer piece (T-section not in contact with the hub ID) on the garyloc gasket have? Is the effect similar to the heel and toe contact of the compact flange?
Mechanimal
Mechanimal
RE: Compact flanges or Grayloc type gasket details
Bill
