Foundation drain for Thickened Slab Building?
I'm doing some work for a non-profit's new 900 square foot building.  The foundation is a thickened slab.  In our typical commercial work, I would always call out for a foundation drain around the perimeter of the thickened floor edge.  However, is it really necessary for such a small structure?  The building is up "high" and the ground is fairly permeable, so ground water should pass right through...
Any thoughts please... trying to save this non-profit some $$$.
RE: Foundation drain for Thickened Slab Building?
What is the purpose of the foundation drain in the first place?  I'm not sure you need such a thing.  Usually foundation drains are used to minimize lateral earth pressure on basement walls.
It minimises water for heaving conditions and helps with the PEVB beneath the slab.  If it's located on a high spot and depending on the soil, it may be a simple matter of venting the perimeter drain to the side of the hill and adding some stone to reduce erosion if water's a problem.
Dik
A perimeter drain is not normal practice in my experience. Therefore, based on that experience, I would say it is not necessary, unless there are particular, site specific, reasons for it.
