ACI 318-08 Appendix D-Shear Breakout
I have a question regarding Section D6.2.4 of Appendix D. This provision tells what to do when anchors are influenced by 3 or more edges, but says nothing about when they are influenced by less than 3 edges. Im working with a program called DSAnchor, and have detailed a bolt arrangement that is in the middle of a wall. Ive made the edge distances (Ca1 and Ca2) large enough (~100") so that no edges should be affected, yet the program seems to still be calculating Ca1 based on provision D6.2.4. In order to make sure that the program is running correctly I want to make sure I understand how Ca1 is calculated, but cant find it in the code. Does anybody know how Provision D6.2.4 should read if the anchors are affected by less than 3 edges? Thanks.
RE: ACI 318-08 Appendix D-Shear Breakout
Diquan
