HTRI INTERFACE WITH CODEWARE COMPRESS PRESSURE VESSEL & HEAT EXCHANGER
HTRI INTERFACE WITH CODEWARE COMPRESS PRESSURE VESSEL AND HEAT EXCHANGER PROGRAM
M. Ueno, Rating Group, said he has updated his version of COMPRESS to Build 6249 and made a report
as the attached file.
1 Always the below "COMPRESS Update" window appears. What is it?
2 Confirmed the latest version is build 6249 and tried to install the program.
3 COMPRESS is growing!
4 HTRI Interface
<----- The units are US. SI units are desirable.
<----- May not be necessary.
5 Why is the tube wall thickness of 1.65mm used in COMPRESS?
6 By the latest tube layout program
Attach is the Verification/Validation by M. Ueno, Rating Group, Chiyoda Corporation
L S THILL
