Water Calculations in Concrete Mix
When calculating the water to cement ratio for a mix, is the water calculated by determining the free water in the aggregates as including the water necessary to bring the aggregate from Oven Dry Condition to Saturated Surface Dry (SSD) condition?
i.e:
Is the water an aggregate contributes to a mix when calculating the water to cement ratio (W/C):
Water = Weight of Aggregate - Weight of Agg. in Oven Dry condition
or:
Water = Weight of Aggregate - Weight of Aggregate in SSD
i.e:
or:
RE: Water Calculations in Concrete Mix
http://concrete.union.edu/design.htm based on the ACI code do not include the free water in the ratio.
Add water = free-water shown on the mix design – aggregate free-water
f
