PSV in the turbine exchaust line
Dear all ..
Can any one tell me ?... what code sholud be following in the steam exchaust line PSV. this is has been designed for blocked outlet conditions...... the turbine is back pressure turbine... the inlet is HP steam and Outlet is LP steam...
RE: PSV in the turbine exchaust line
I'm not 100% certain, though. It would be great if someone with more experience could comment.
You can confirm with your mechanical or vendor which design code the turbine has been designed for. The design code could be ASME VIII, JIS, GB, DIN, etc...Your overpressure protection system shall be designed to fulfill requirement stated in the design code.
