Category D Welds in Lethal Service Vessels
Can nozzles be welded into shells or heads of lethal service vessels the "normal" way, for example, in accordance with UW-16.1(e)? Or is it required to be welded in so radiography can be performed on the joint, as shown in, for example, UW-16(f-4)? I am not seeing a requirement for radiography on category D joints, but then again, I may not be looking in the right place.
Thanks in advance,
Michigander.
Thanks in advance,
Michigander.
RE: Category D Welds in Lethal Service Vessels
What is the vessel material?
Best Regards,
Michigander
Yes. Full penetration corner weld Category D joints are acceptable for lethal service. Radiography for this type of joint is not required.
Thanks again!
Michigander
Or does the language only apply to the welds IN nozzles, not the welds of nozzles to vessels?
