Natural Gas Line Temperature Distribution
For gas line flow losses is isothermal flow the norm?. If not, what thermal considerations are given in determining fluid flow hydraulic losses?
RE: Natural Gas Line Temperature Distribution
Underground pipeline, pipe rack, distance?
Any info would suffice.
for long lines with hot gases going in, you'll need to do heat loss calculations.  Break the line into 1/2 miles sections with Tin Tout.
agree with the last post
Pipelien studio (and HYSYS etc.) can do this for you, including pipes in free air, water or duried.
Best regards
Morten
