Error: Load set not found on result file.rst
Please, anyone knows what it means?
I'm simulating an explicit analysis test, Ansys solves it , but I can use post26 only,trying post1 ansys issues this error
tnx 4 answers
tnx 4 answers
RE: Error: Load set not found on result file.rst
depending on the type of analysis you are doing, the result file could have different extensions (*.rst, *.rfrq etc.)
The command file FILE could solve your problem.
Alex
that happens with my explicit analysis last model only
