Use of its
Use of its
Which is the correct use of its (or it's)
This is for the benefit of xxx and its partners
or
This is for the benefit of xxx and it's partners
or
RE: Use of its
This is a really common grammatical mistake, one that I sometimes make and kick myself for it later.
- Steve
RE: Use of its
RE: Use of its
RE: Use of its
More info...
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: Use of its
RE: Use of its
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
RE: Use of its
RE: Use of its
RE: Use of its
It's not its, it's it's.
Hope that helps
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: Use of its
That can't be correct! It must supposed to be:
It's not its, it's its.
¡papá gordo ain't no madre flaca!
RE: Use of its
The original was correct. Spell it out:
It is not "its", it is "it is."
Meaning, any time you write "its" and add that darn apostrophe you mean "it is". If the sentence doesn't make sense with "it is" in there, then remove the apostrophe.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: Use of its
- It (the word you want) is not "its," it (the word) is "it's."
- It (an object) is not its (a possession of an "it"), it (the same object) is its (a possession of some other "it", apparently).
RE: Use of its
- Steve
RE: Use of its
Heck, if I type too quickly and don't proof read well enough I still get it wrong.
However, in any kind of formal communication it's sloppiness and can distract from the technical veracity of the document.
KENAT, probably the least qualified checker you'll ever meet...
RE: Use of its
f-d
RE: Use of its
There's bound to be some strange sentence construction in which this trick doesn't work, but I have not seen it.
RE: Use of its
Rule 2: Where rule 1 causes the same form, use the apostrophe for the contraction only.
RE: Use of its
Possessive pronouns never use apostrophes, so Rule 1 is wrong. For nouns, a -'s ending can mean either a contraction of noun + is, or a possessive form of the noun, but they look the same, and Rule 2 is wrong.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
RE: Use of its
I'da written it:
This is for the benefit of xxx and THEIR partners
f-d
RE: Use of its
That would work only if xxx was plural:
This is for the benefit of companies and THEIR partners.
This is for the benefit of the company and ITS partners.
Just sayin'...
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
RE: Use of its
I'm with you on the usage of ITS and THEIR. But I corrected someone in another thread, only to be told that THEIR in the singular is acceptable, based on usage by Shakespeare, Dickens, Austen, Chaucer, OED, King James Bible, etc., etc.
My authority is only Miss Shaw, Miss Barnes, etc., etc., but I still think we are correct.
RE: Use of its
RE: Use of its
It is starting to become more recognized as legit by the powers that be, and if we continue their usage in this way, it will become proper grammar in very short time (maybe within our life times).
In this case, though, I agree with JM. :)
Matt Lorono
Silicon Valley, CA
RE: Use of its
RE: Use of its
Matt Lorono
Silicon Valley, CA
