Assembly Relantionships
Hi, is there anyway in V20, when using a Connection relationship to limit it to only select mid-points of edges, I am finding it very dificult and time consuming to locate the mid-point of edges, it seems like I have to have the curser exactly on that point before it will show up in the multi-pick, this is not always easy to do and often takes many attempts. In V19 SE used to highlight the mid-point if you hovered over it, this does not appear to happen in V20, so I'm not sure if it is just an option I have not selected or a change in package.
RE: Assembly Relantionships
that's a 'glitch' in V20 I don't know at the mo whether there is
already call opened for this
dy
Thanks, I found that the further you zoom out from the edge the easier it is to find the mid-point using the multi-pick.
