Reports In Access How do I use VBA
Hello Everyone,
I have an Access Report with 3 fields Name,Code,and Amount fields.  I need to generate totals at the end of the report if some conditions are met.  For example: if the code field is equal to A then sum all the amounts in the amount field and display the totals at the end of the report.  There are 6 different codes and I need to be able to calculate total amounts for each code within the report.
If anyone can help me then it would be greatly appreciated.
Neak1
RE: Reports In Access How do I use VBA
Search for "If...then...else" in Access help.
Use queries to generate your totals then insert the results in your report.
