Looking for ANSI B16.47 series A & B Flange bolting chart
I'm working on a project that requires replacing some 36" pipe. I typically don't work with this large of diameter pipe. I've been able to find ANSI B16.47 series A & B Flange dimension tables but not bolting charts. Can anyone help?
Thanks, Lud
Thanks, Lud
RE: Looking for ANSI B16.47 series A & B Flange bolting chart
A chart of bolt diameters and lengths for each flange size and class rating similar to the bolting chart for ANSI B16.5 flanges that can be found at the Texas Flange Co's web site. http:/
I was able to find a copy of API 605, which does list bolt lengths. This, if I'm correct, should match the ANSI B16.47 Series B. So at this point I'm still looking for bolting info. on the ANSI B16.47 Series A.
That's my problem. I have been unable to get my hands on a copy of ASME B16.47. I was hoping someone would be able to point me to something similar to the chart for B16.5 flanges that many flange manufactures publish for reference.
I've calculated the stud length that I need for my current project. I was just hoping to be able to have a complete chart for future use.
Thanks, Lud
I was also looking for this.. and found this site:
http:
Hope it is any good to you.
