The requirements for the water in a chilled water system?
What are the minimum requirements for the water used in a chilled water system that is used in a chiller system with condensers. And what are the additives that need to be added to the water?
RE: The requirements for the water in a chilled water system?
Thank you,
Itesa
Um, you are a little off topic, but here ya go. Quoting from Encyclopedia Britanica "Enthalpy is the sum of the internal energy E and the product of the pressure P and volume V of a thermodynamic system". Handy in a college level thermodynamic course, but in the HVAC real world not generally used.
KW/ton however, is a valid measure of efficiency, and a good yardstick by which to evaluate systems. For a chiller, it is usually listed in the manufacturers data. For a central plant, you need to add up all the power consumed by chiller, pumps, and cooling towers (if applicable), and divide by the chiller output in tons.
