some suggestions about COMPRESS
I have some suggestions about the COMPRESS software, maybe it is not intended as a venue for technical support and should not be used as the primary means of technical support, but it will be more convenient for the USERS.
1. Can COMPRESS report CONTENT with page numbers?More and more customers require that. It may be easier for COMPRESS to do that. We usually edit the content by hand; I think it is waste time.
2. Can COMPRESS add an option about COPY EXISTENT on the STIFFENER RINGS? When i design a tall tower, there are more than 10 rings on it. And the distance between the rings is not always the same. So i need a COPY EXISTENT button to lighten my work.
3?Can COMPRESS set a data inputs summary in the report file? It will be convenient for the designer to check the data.
Suave
RE: some suggestions about COMPRESS
Hi, Vida
A good suggestion.
I have a same inconviniency like you.
I hope those would be reflected and accepted in next version soon.
koplan
thank you for your reply.
there is another item which is more worth expecting. that's calculation about BELLOW according to APPENDIX 26 which is constrained by ASME. now i have to calculate it by hand. it's a very tiring thing. do you have a good way to deal with it?
