Export Macro for ACIS/STL?
Hi All,
I'm just wondering if anyone has a macro handy for exporting ACIS/STL that you wouldn't mind sharing.  I'm mucking around the help file and it seems like on one hand I ought to be able to pull this off but then I try to tie everything together there are missing pieces.  Seems as though I ought to be able to pull this off using the API (ModelDocExtension.SaveAs).
Chris Gervais
Application Engineer
CSWP, CSWST
RE: Export Macro for ACIS/STL?
Here is a link to an oldie but a goodie called Pac4SWX:
http://swtools.cad.de/us_prog_pac.htm
It will batch print and batch convert.  It has a free trial.
-Dustin
Professional Engineer
Certified SolidWorks Professional
