PSV Noise Attenuation Through Tailpipe
Hi Guys. I have a PSV that will relieve 160,000 lbm/hr. Service is saturated steam of 70% quality. The PSV is located inside the plant limits. I can't move it outside the plant for a whole host of reasons.
The system design is robust and is fully designed against the need for the PSV. But, as they say, sh*t happens, and that's why the Code requires PSVs in real life. So I have to deal with the possibility of a high noise level during a relief event.
One solution is a silencer. Another soution is to pipe the PSV tailpipe/discharge pipe out of the plant to outside the plot limit and no silencer needed. My calcs show that I need to be 250' away from the plant, as the crow flies, to get the noise level down to the owner-mandated SPL (114 dBA at 3'). This of course assumes no attenuation caused by the long tailpipe. A diffuser will be installed at the end of the tailpipe to break up the velocity of the exit stream.
The question is, how much SPL attenuation will I get due to the 250' run of pipe? I have a hunch that I can get down to the required 114 dBA using less than 250' of pipe.
I searched the forum here but no luck yet. I haven't found anything in any vendor's literature yet either.
Thanks guys!!!! Pete
RE: PSV Noise Attenuation Through Tailpipe
It is a little odd that you would worry about noise levels on a psv discharge. Should be a very infrequent event associated with some process upset.
I would use a silencer or different psv if it is truly necessary.
Take a look at this link for RV info:
http
Here are some links on noise:
ht
http://ww
htt
Silencers built for steam PSVs are a mature, developed technology.
Your total cost for a properly sized silencer would be less than the 250' of piping plus the systems difficulties that would occur.
Try discussing your problem with these guys..... I have had good luck.... they are practical and smart....
http://www.universal-silencer.com/pdfs/HV.pdf
Be responsible and complete this thread with details of your final decision
-MJC
Me? Responsible? Just ask my wife! Pete
