Navy Air Warfare Center Report
I'm looking for a technical report, NADC 83084-60 "Non-Autoclave Processing for Composite Material Repair". I had a post in the Composite Material forum but got no love. I've seen the report referenced in multiple public documents so it seems it should be available somewhere.
Does anybody have this report or know where I can get a copy? I've searched high and low on the web with no luck, (NASA, STINET and Google).
RE: Navy Air Warfare Center Report
I would like to see it too, but it is almost certainly an export controlled document. As such you will not find it anywhere that foreign nationals could access it. You will have to contact the right department at the Navy and request a copy. You will probably have to provide a copy of DD2345 which shows that you or your company is cleared for access. Getting this clearance is not difficult and you can find that info on the web. Once you have the document you are responsible to control its distribution.
Do you have any current government contracts?  If so you may be able to request it through that path.
KENAT, probably the least qualified checker you'll ever meet...
Thanks all for the replies. I have contacted the appropriate Navy department and found out that it is indeed restricted to US Government &/or contractors. I'm currently trying to determine what my company has for government contracts and proceed as Kenat has suggested.
