Mold design add on package??
I'm new to the forum, but not Solid Edge.
I have a demo for the Mold Design package. Does anyone use it and how do I get started?
Thanks.
RE: Mold design add on package??
when this is a demo that requires MoldDesign then you have
to buy it at $$$$ it's not standrad in SE.
When you have a license for it then it can be reached via
Applications --> MoldTooling (menue entry is active then)
dy
donyoung,
Thanks. I do have a temp. license for the mold tooling.
I tried that and can't find it as an option. Did I load it from the DVD incorrectly?
hard to say because I don't own it. Usually you install extras
from the DVD then add the approriate license string to your
license file and that's it.
BTW: MoldTooling is available only from within the assembly
environment.
dy
OK.
I got it. I didn't realize that you needed to be in the assembly environment.
Now I just need to know how to use it.
Thanks.
you may check this site. It's run by distrim of portugal
they have developed that stuff for SE:
Mold Tooling
dy
